Development
Bug Fixes
- When regridding with mesh refinement the finer levels must be remade (exa/mfix!1282)
- Add missing header to mfix_solvers.H (exa/mfix!1281)
- Fix missing enthalpy reactions RHS term in fluid predictor (exa/mfix!1280)
- Fix a tiling bug (exa/mfix!1275)
- Fix illegal GPU memory access in particle initialization (exa/mfix!1273)
Maintenance
- Bump hydro and amrex. fix compilation error (exa/mfix!1284)
- Remove mfix.H dependence from deposition operation (exa/mfix!1283)
- Moving files around for improved reuse (exa/mfix!1279)
- Remove reference to
mfix_mass_balance in util/Make.package (exa/mfix!1278)
- Reorganize src/util directory (exa/mfix!1277)
- Add sanity check on enthalpy function continuity (exa/mfix!1268)
- Make tangential dem model settings optional (exa/mfix!1266)
- Fix GPU memory addresses for chemistry (exa/mfix!1265)
CI, regression testing, and unit tests
- Fix CI to run OMP ctests (exa/mfix!1276)
Tools/Apps
