MFIX-Exa 25.08 Release Notes
Improvements/new capabilities
  • Re-enable the depdt constraint option (exa/mfix!1498)
Bug fixes
  • Generalize NASA7 temperature input (exa/mfix!1490)
  • Compute solids temperature from enthalpy after chemistry solve (exa/mfix!1495)
Code cleanup
  • Adjust time dependent inflow logic (exa/mfix!1469)
  • Disable tracers in plotfile when not solved (exa/mfix!1491)
  • Rework the leveldata class (exa/mfix!1492)
  • Add stepdata to fluid update (exa/mfix!1500)
  • Do not force inlining for chemical reaction rates (exa/mfix!1505)
  • Cleanup projection routines (exa/mfix!1506)
CI and test changes
  • Address ctests failures after MR1498 (exa/mfix!1499)
  • Update tests: revert exa/mfix!1499 (exa/mfix!1502)
Subproject updates
  • none
Tools updates and fixes
  • Allow the rates optimization tool to handle names with dashes (exa/mfix!1493)
  • Allow no-fluid/particle species in rates optimization script (exa/mfix!1504)
  • post-mfix: skip checks on AmrCore inputs (exa/mfix!1507)
MFIX-Exa 25.08 has been released on the website. Please report any issues or bugs here on the forum.
