MFIX-Exa 26.07 is available for download.
Improvements/new capabilities
- Add slip and no-slip wall options (exa/mfix!1878)
- Add EB support to interface (exa/mfix!1872)
- Add lift force to fluid-particle coupling (exa/mfix!1864)
- Define fluid inflow BCs using Parser expression (exa/mfix!1853)
- Enable coupling-side vorticity storage for lift models (exa/mfix!1859)
- Add build-system wiring and ISAT compile-gate (exa/mfix!1843)
Bug fixes
- Correct fixInputs for bc pressure (exa/mfix!1885)
- Update BC fab area for rotating-reference (exa/mfix!1884)
- Rotating reference frame region handling (exa/mfix!1882)
- Avoid allocating temp GPU arrays for RRF (exa/mfix!1877)
- Store BC fluid volfrac (exa/mfix!1875)
- Correct velocity parsing for BCs (exa/mfix!1873)
- Virtual mass bug fixes (exa/mfix!1871)
- Replace host pointer with GPU array (exa/mfix!1865)
- Chem guardrail: compute_dt before chemistry, not after (exa/mfix!1855)
- Fill all velocity ghost cells for eddy viscosity (exa/mfix!1849)
- Preserve particle-factory alias for single grid load balance (exa/mfix!1848)
Code cleanup
- Consistent domain boundary ghost-cell fill (exa/mfix!1883)
- Remove duplicate function (exa/mfix!1881)
- Simplify fluid inputs for interface (exa/mfix!1879)
- Improve solids conduction handeling (exa/mfix!1874)
- generalize compute cell grad (exa/mfix!1868)
- Move vorticity to MFIXFieldOps namespace (exa/mfix!1858)
- Remove FillPatchVelForVort (exa/mfix!1857)
- replace burner_verbose with chemistry.report_level (exa/mfix!1856)
- CHEM-EXIT backstop diagnostic (exa/mfix!1854)
- positivity projection of post-integration species (exa/mfix!1852)
- Remove epf from mac vel and fluid BC settings (exa/mfix!1850)
CI and test changes
- Update FLD08 test data (exa/mfix!1867)
GUI updates
- fix virtualgl autodetection (exa/mfix!1880)
- use “almost_equal” in grid spacing check (exa/mfix!1851)
Subproject updates
- Bump pyamrex for AMReX requires-clause API (pyamrex#571) (exa/mfix!1869)
- Bump submodules (exa/mfix!1866)
Tools updates and fixes
- none
