Hello everyone,
I tried to install MFiX on Linux, I followed the instruction below: https://mfix.netl.doe.gov/doc/mfix/19.1.3/getting_started/install-linux.html
Everything seemed to be correct, but when I run the command “mfix” (in order to open the software), I got the following error:
“Segmentation fault”
I would be grateful if you help me with this error,
Kind Regards,
Saeed
Can you try running:
mfix --novtk
If that works then it might be a graphics issues.
Thank you very much for your reply,
I tried the command, the same error:
How should I check/fix graphics issues ?
Thanks,
Saeed
Saeed:
Try running the command
$ conda list > env.yml
and click on the Upload button to attach the env.yml file to a post. If I can reproduce your environment, maybe I can diagnose the issue.
-Mark
