I tried to install MFIX using conda environment, copy pasted the cmd from the webpage, this worked fine. However when I try to run mfix I get an error with numpy. I have found that this might be caused by updated numpy version 1.20.2 (but downgrade to version 16 was not possible due to conflicts). On the other hand someone suggested to use python 3.8 or newer instead of 3.7, however I had same problems with conflicts. Any idea how to solve it? Thank you very much.
File "/home/jiri/.conda/envs/mfix-21.1.4/bin/mfix", line 6, in <module>
from mfixgui.gui import main
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/mfixgui/gui.py", line 68, in <module>
from .file_menu import FileMenu
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/mfixgui/file_menu/__init__.py", line 24, in <module>
from mfixgui.widgets.nodeworks import NODEWORKS_AVAILABLE
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/mfixgui/widgets/nodeworks.py", line 42, in <module>
from mfixgui.vtk_widgets.geometry_engine import GeometryEngine
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/mfixgui/vtk_widgets/geometry_engine.py", line 39, in <module>
from mfixgui.tools import procedural_stl
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/mfixgui/tools/procedural_stl.py", line 7, in <module>
import splipy as sp
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/splipy/__init__.py", line 3, in <module>
from splipy.BSplineBasis import BSplineBasis
File "/home/jiri/.conda/envs/mfix-21.1.4/lib/python3.7/site-packages/splipy/BSplineBasis.py", line 8, in <module>
from splipy import basis_eval
File "splipy/basis_eval.pyx", line 1, in init splipy.basis_eval
ValueError: numpy.ufunc size changed, may indicate binary incompatibility. Expected 216 from C header, got 192 from PyObject
Conda packages
# packages in environment at /home/jiri/.conda/envs/mfix-21.1.4:
# Name Version Build Channel
_libgcc_mutex 0.1 main
_openmp_mutex 4.5 1_gnu
blas 1.0 mkl
brotlipy 0.7.0 py37h27cfd23_1003
bzip2 1.0.8 h7b6447c_0
ca-certificates 2021.5.25 h06a4308_1
certifi 2021.5.30 py37h06a4308_0
cffi 1.14.5 py37h261ae71_0
chardet 4.0.0 py37h06a4308_1003
click 8.0.1 pyhd3eb1b0_0
cmake 3.14.0 h52cb24c_0
cryptography 3.4.7 py37hd23ed53_0
curl 7.71.1 hbc83047_1
cycler 0.10.0 py37_0
dbus 1.13.18 hb2f20db_0
expat 2.4.1 h2531618_2
flask 1.1.2 pyhd3eb1b0_0
fontconfig 2.13.1 h6c09931_0
freetype 2.10.4 h5ab3b9f_0
future 0.18.2 py37_1
git 2.23.0 pl526hacde149_0
gitdb 4.0.7 pyhd3eb1b0_0
gitpython 3.1.18 pyhd3eb1b0_1
glib 2.68.2 h36276a3_0
gst-plugins-base 1.14.0 h8213a91_2
gstreamer 1.14.0 h28cd5cc_2
hdf4 4.2.13 h3ca952b_2
hdf5 1.10.4 hb1b8bf9_0
icu 58.2 he6710b0_3
idna 2.10 pyhd3eb1b0_0
importlib-metadata 3.10.0 py37h06a4308_0
intel-openmp 2021.2.0 h06a4308_610
itsdangerous 2.0.1 pyhd3eb1b0_0
jinja2 3.0.1 pyhd3eb1b0_0
jpeg 9b h024ee3a_2
jsoncpp 1.8.3 h3a67955_0
kiwisolver 1.3.1 py37h2531618_0
krb5 1.18.2 h173b8e3_0
lcms2 2.12 h3be6417_0
ld_impl_linux-64 2.35.1 h7274673_9
libcurl 7.71.1 h20c2e04_1
libedit 3.1.20210216 h27cfd23_1
libffi 3.3 he6710b0_2
libgcc 7.2.0 h69d50b8_2
libgcc-ng 9.3.0 h5101ec6_17
libgfortran-ng 7.5.0 ha8ba4b0_17
libgfortran4 7.5.0 ha8ba4b0_17
libgomp 9.3.0 h5101ec6_17
libnetcdf 4.6.1 h11d0813_2
libogg 1.3.5 h27cfd23_1
libpng 1.6.37 hbc83047_0
libssh2 1.9.0 h1ba5d50_1
libstdcxx-ng 9.3.0 hd4cf53a_17
libtheora 1.1.1 h5ab3b9f_1
libtiff 4.1.0 h2733197_0
libuuid 1.0.3 h1bed415_2
libvorbis 1.3.7 h7b6447c_0
libxcb 1.14 h7b6447c_0
libxml2 2.9.12 h03d6c58_0
lz4-c 1.8.1.2 h14c3975_0
markupsafe 2.0.1 py37h27cfd23_0
matplotlib 3.3.4 py37h06a4308_0
matplotlib-base 3.3.4 py37h62a2d02_0
mfix 21.1.4 0 https://mfix.netl.doe.gov/s3/03e5531d/98ca962d3d15e6abadf69ab4b99049d5/conda/dist
mfix-doc 21.1.4 0 https://mfix.netl.doe.gov/s3/03e5531d/98ca962d3d15e6abadf69ab4b99049d5/conda/dist
mfix-gui 21.1.4 py_0 https://mfix.netl.doe.gov/s3/03e5531d/98ca962d3d15e6abadf69ab4b99049d5/conda/dist
mfix-solver 21.1.4 py37h3218e01_0 https://mfix.netl.doe.gov/s3/03e5531d/98ca962d3d15e6abadf69ab4b99049d5/conda/dist
mfix-src 21.1.4 0 https://mfix.netl.doe.gov/s3/03e5531d/98ca962d3d15e6abadf69ab4b99049d5/conda/dist
mkl 2021.2.0 h06a4308_296
mkl-service 2.3.0 py37h27cfd23_1
mkl_fft 1.3.0 py37h42c9631_2
mkl_random 1.2.1 py37ha9443f7_2
ncurses 6.2 he6710b0_1
numpy 1.20.2 py37h2d18471_0
numpy-base 1.20.2 py37hfae3a4d_0
olefile 0.46 py37_0
openssl 1.1.1k h27cfd23_0
packaging 20.9 pyhd3eb1b0_0
pcre 8.45 h295c915_0
perl 5.26.2 h14c3975_0
pillow 8.2.0 py37he98fc37_0
pip 21.1.2 py37h06a4308_0
psutil 5.8.0 py37h27cfd23_1
pycparser 2.20 py_2
pyopenssl 20.0.1 pyhd3eb1b0_1
pyparsing 2.4.7 pyhd3eb1b0_0
pyqt 5.9.2 py37h05f1152_2
pyqtgraph 0.11.0 py_0
pysocks 1.7.1 py37_1
python 3.7.10 h12debd9_4
python-dateutil 2.8.1 pyhd3eb1b0_0
pyyaml 5.4.1 py37h27cfd23_1
qt 5.9.7 h5867ecd_1
qtpy 1.9.0 py_0
readline 8.1 h27cfd23_0
requests 2.25.1 pyhd3eb1b0_0
rhash 1.4.1 h3c74f83_1
scipy 1.6.2 py37had2a1c9_1
setuptools 52.0.0 py37h06a4308_0
simpleeval 0.9.8 py_0 mfix
simplejson 3.17.2 py37h27cfd23_2
sip 4.19.8 py37hf484d3e_0
six 1.16.0 pyhd3eb1b0_0
smmap 4.0.0 pyhd3eb1b0_0
splipy 1.4.0 py37h3218e01_0 mfix
sqlite 3.36.0 hc218d9a_0
tbb 2020.2 hff7bd54_0
tk 8.6.10 hbc83047_0
tornado 6.1 py37h27cfd23_0
typing-extensions 3.7.4.3 hd3eb1b0_0
typing_extensions 3.7.4.3 pyh06a4308_0
urllib3 1.26.4 pyhd3eb1b0_0
vg 1.9.0 py37hd844fa7_0 mfix
vtk 8.2.0 py37haa4764d_200
werkzeug 1.0.1 pyhd3eb1b0_0
wheel 0.36.2 pyhd3eb1b0_0
xz 5.2.5 h7b6447c_0
yaml 0.2.5 h7b6447c_0
zipp 3.4.1 pyhd3eb1b0_0
zlib 1.2.11 h7b6447c_3
zstd 1.3.7 h0b5b093_0
