After the mfix set time runs, can I reset the time and continue running along the current calculated result? Or do you have to start from scratch every time? If it can continue to operate, what is the method
Yes, you can continue an MFiX run. See the MFiX manual
Note the message “Previous MFiX run is resumable”.
Some of the controls in the GUI are locked (disabled), such as model geometry and initial conditions. But the stop time control in the Run pane is available.
Then when you start the run, select “Restart” in the run popup.
This will start from the data in the last .RES file. You can control the frequency of saving RES files here:
Thank you for your answer
