I had some cases that worked fine on mfix22.1.1, but suddenly I couldn’t build the solver. So I deleted MFix22.1.1 and tried to reinstall it, but the installation failed.
I changed my computer and still couldn’t install mfix22.1.1.
Sorry for the delayed response. The file mfix-doc-22.1.1 was somehow deleted from our server. Fortunately I was able to re-generate the docs for 22.1.1 and replace the missing file. You should be able to install version 22.1.1 without trouble now.
However I am interested to know why you cannot use the new version. MFiX 24.3 was released today. What problems are you having that are forcing you to use 22.1.1 (over two years old)?
Thank you very much for your reply. Since I changed a lot of the source files based on 22.1.1, changing versions required me to reprogram them, which was cumbersome. But I’m still using the new version.
