Dear All,
I can not find the options to Monitor/Measure/Output the mass/solid flowrate nor the bulk density in the regions. Would you mind telling me where to find them? Thank you.
Dear All,
Items which are disabled (“greyed out”) in the GUI are not compatible with the model used. If you hover over disabled items, the popup text (“tooltip”) will offer further information.
Again, not every feature is compatible with every model. Disabled controls are a feature, not a bug.
Thank you Charles. So if there are no such options, how can I manage to measure the mass flowrate or compute the output particles per second under the PIC/DEM methods? Thank you.
You need to look a little harder:
