MP-PIC: How to Adjust the Gas–Solid Heat-Transfer Correlation in MFIX?
Hello, developers!
I am currently working on MP-PIC simulations, but I am not sure whether this is simply due to my limited familiarity with the software. I have not been able to find an option for adjusting the Nusselt number correlation, similar to the one available in DEM simulations.
Since my understanding of the MP-PIC model is still quite limited, I would like to ask: Is gas–solid heat transfer neglected in MP-PIC simulations? Or does MFIX use a default gas–solid heat-transfer model or Nusselt number correlation for MP-PIC, without providing an option to adjust the Nusselt number correlation as in DEM simulations? If I want to change the Nusselt number correlation being used, would I need to modify the MFIX source code to do so?
I would greatly appreciate any help or guidance. Thank you very much!
