Hello, what is the reason for the error in the following picture? Thank you
tansuanhua_xiao_2022-11-02T223311.620108.zip (156.4 KB)
Looking at the LOG file:
WARNING from utilities_mod.f:169
Velocity exceeds limit: 26.209
in cell: I = 7 J = 6 K = 2
Epg = 0.86554 Ug = -8.1864 Vg = -26.209 Wg = 0.0000
t= 0.1000 Dt= 0.1075E-09 NIT= 2MbErr%= 0.3754E-13: Run diverged/stalled :-(
ERROR from time_step.f:193
The MPI_FINALIZE warnings are somehow causing this message to not be displayed. I’ll fix that. But this looks like a familiar type of convergence failure.
Thank you for your reply. I adjusted the intake speed and the problem was solved.
What is the relationship between dt and dt_min and the intake velocity in BC? Do you have a specific formula? thank you
