Hello, I want to do a simulation with mppic method to realize that the green area in the figure is the entrance of a particle, and the red ring area is the exit of a pressure
But there are two problems we need help with
The error file is as follows:
0606_mppic.mfx (15.8 KB)
0606_mppic_2024-06-07T100622.930087.zip (8.2 MB)
- If I select the green area by stl method, an error will be reported when I set it as the flow inlet, and the volume fraction of imported particles cannot be adjusted. If I do not use the stl option, the particle inlet can be defined, but I also encounter problem 2
2. The pressure outlet cannot be established. If the ring surface is selected with stl, the following error will appear
I want to realize granule green entry and red exit, what should I do, looking forward to your help
