Hello Community:
After I try to build a solver, I met this error. Does anyone know how to deal with this problem. Thank you!
Hello Community:
MFiX 22.2 is coming out this week and will have full MacOS support, including the default solver and the needed compiler fixes to build your own solver. Stay tuned!
Hey, I just download the latest version. It works now with a default solver. Thank you!
Note that due to a small error in packaging the release, the Fortran compiler is not bundled with MFiX, so if you need to build a custom solver, go to a terminal window, activate the mfix-22.2 environment, and issue the command
conda install -c conda-forge fortran-compiler
(change conda to mamba if using miniforge/mamba)
