In chemical reaction, which first or second type should be used to decompose a single solid particle into solid and gas? If mfix-DEM model is selected.
If you use the MFiX GUI to setup your project, the reactions will get put into the correct section of the file and you won’t have to worry about it. Are you constructing the files from scratch?
