Hi, I reported this error when running, I would like to ask what is the problem, thank you.
Hi Wangyi -
As always, it is best to attach your project when seeking help. In the main menu, ‘Submit bug report’ will create a ZIP file containing all relevant files.
However, this error message is pretty straighforward - one of your reacting phases (fluid or one of the solids) has “Specific heat” set to “Constant” as in this screnshot:
You need this to be “Mixture” (or UDF if you are using custom code, which is probably not the case here).
Ok, thank you for your reply. I will pay attention to the issue of additional items in the future. Thank you!
