Dear community,
I’m running a pure granular DEM simulation and I got this error when I try to save the particle position under tecplot format. The number of particles is 226771 and the system has 32 Gb RAM. The initial file is saved (**_DES_DATA_0000.dat) but when it tries to save the next time step it crashes. vtp files are written normally.
Operating system error: Cannot allocate memory
Allocation would exceed memory limit
Error termination. Backtrace:
#0 0x7f28b08a8d01 in ???
#1 0x7f28b08a9849 in ???
#2 0x7f28b08a9aa4 in ???
#0 0x7f6f99513d01 in ???
#1 0x7f6f99514849 in ???
#2 0x7f6f99514aa4 in ???
#3 0x55d325d8391d in __write_des_data_mod_MOD_write_des_tecplot
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/des/write_des_data.f:355
#4 0x55d325d84419 in __write_des_data_mod_MOD_write_des_data
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/des/write_des_data.f:64
#3 0x559a21bd991d in __write_des_data_mod_MOD_write_des_tecplot
#4 0x559a21bda419 in __write_des_data_mod_MOD_write_des_data
#5 0x55d325bac9f4 in __write_spx1_mod_MOD_write_spx1
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/write_spx1.f:98
#5 0x559a21a029f4 in __write_spx1_mod_MOD_write_spx1
#6 0x559a219662e4 in __output_man_MOD_output_manager
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/output_manager.f:125
#7 0x559a2191305f in __des_time_march_MOD_des_time_step
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/des/des_time_march.f:244
#6 0x55d325b102e4 in __output_man_MOD_output_manager
#7 0x55d325abd05f in __des_time_march_MOD_des_time_step
#8 0x55d325abbfdf in run_dem
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/mfix.f:211
#9 0x55d325abbfdf in run_mfix_
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/mfix.f:146
#10 0x55d325abc476 in mfix
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/mfix.f:298
#11 0x55d325abb698 in main
at /home/fer/anaconda3/envs/mfix-20.4.0/share/mfix/src/model/mfix.f:269
#8 0x559a21911fdf in run_dem
#9 0x559a21911fdf in run_mfix_
#10 0x559a21912476 in mfix
#11 0x559a21911698 in main
Process name: [[6562,1],2]
Exit code: 1
