Dear forum,
I am facing an unknown error when trying to solve a simple PIC case with two gas species. I am not interested in the chemistry but the fact that there are two gas species in my model. I set everything and it can run if only one gas phase is used but, as soon as I enable species_eq(0), the simulation stops after the first time-step stating “Previous MFiX run is resumable. Reset job to edit model”.
I have tried to enable the energy equation, but then I get as many errors as particles XX in the system stating that “The initial species mass fraction for particle XX does not sum to one. Verify that the IC region containing this particle has the solids species mass fractions defined: IC_X_s(ICV,1,:).”
I suspect this is a rather simple question, but I am unable to see where my problem is and I would kindly appreciate any help. Please see below the case I am using.
Thanks!
Eduardo
PIC_model.mfx (18.0 KB)
