Hello Everyone,
I’ve set up 2 nearly identical case for a fluidized bed of spherical particles one using the superquadric solver the other using the DEM solver. I’m using the Di Felice Ganser drag model (since it is available for both solvers) but notice a very large difference in predicted pressure drop between the two models. The DEM solvers aligns with the experimental data at ~425Pa pressure drop, while the superquadric predicts a pressure drop of ~115Pa. Note dP is measured from the bottom of the column to 0.31m, I’ve included the pressure drop files under the name “PressureTop” and “PressureBottom” in both cases. I know it is atypical to use the superquadric solver for a spherical particle but this problem arose because I was getting an unexpectedly low pressure drop in a similar system of cylindrical particles. I figured going back to spherical particles would be a good starting point for troubleshooting. Does anyone else have experience with this? Am I making an error when setting up my superquadric case?
SphereDEMDFG_U_14.zip (5.1 MB)
SphereSQPDFG_U_14.zip (8.4 MB)
