Problem about the steady state simulation of fluidized bed
Hi everyone!
Recently, I am trying to simulate the steady state of a fluidized bed by TFM. The case just involves the energy equation, there is no species or reactions. However, The MFiX 24.2.3 reported the following error:
Error: Solver crash!
Error information:
float divide by zero in __dgtsv_mod_MOD_dgtsv
at DGTSV.f:190
I do not know what is wrong with it. I noticed that there are some similar topics in the forum but there is no reply, so I want to ask this question again.
The mfx file is attached, thank you very much!
Ammonia_3D.mfx (19.8 KB)
It seems that the setting of steady state is not appropraite. I advise that changing the case to a transient simulation. If you want the results at the steady state, you can just simulate the cases for a period of time until the main parameters remain almost constant.
Thank you for your reply! I will try to do some transient simulation.
By the way, I still want to know the reason about this problem, could you give me some advise about it?
Sure!
In the physical landscape, the physical quantities in each cell are not kept constant with time. They are always oscillate slightly around a certain value. Therefore, it’s may be more apporiate to capture the features about the system by non-steady simulations.
OK! I got it, Thank you very much!
