Hi! I am using SMP for parallel computing on our server. It seems working normally but the DASHBOARD.TXT shows “Serial run”. It makes me confusing that if the case running serially or parallelly?
command:
env OMP_NUM_THREADS=64 ./mfixsolver -f ./fluid_bed_tfm_2d_test.mfx
| MFIX DASHBOARD |
| RUN_NAME = FLUID_BED_TFM_2D_TEST |
| Description = 2D TFM FLUID BED |
| Run Status = In Progress… |
| CPU time elapsed = 3.8 days |
| CPU time left = 15.5 days |
| Latest vtu file = ./VTU/FB2D_0056.vtu |
| Serial run |
| Name | Value | Min | Max | % of max|0% Progress 100%|
| Time | 0.57E+00| 0.00E+00| 0.30E+01| 18.8 % |===== |
| DT (+) | 0.35E-03| 0.72E-04| 0.10E-02| 34.9 % |========= |
| Sm | 0.11E+03| 0.11E+03| 0.11E+03| 100.0 % |===========================|
| NIT | 17| 2| 240| 7.1 % |== |
| Max res | P0 | | | | |
||||||__________________|
Last updated at: 18:17:41 on: 05/20/2021
