Problem with installing node works
How do I install nodeworks for MFIX 26.1? This link contains an error. Regards
You didn’t imbed a hyperlink. Are you having this :backhand_index_pointing_up: same issue? It seems the correction never got pushed to the online docs.
Thank you. I installed NodeWorks :slight_smile:
I’d like to fix the docs. Where is the broken link?
The link has been fixed
thanks, charles 123456789
