Problems when running mfix-24.2.3 on Ubuntu, whilst no problem on Windows
Dear support and community,
I am facing an issue with a very simple simulations (attached the .mfx file). The issue is that the simulation runs perfectly fine on Windows, while, with exactly the same input file and same version of mfix, I get these errors on Ubuntu:
Error 1
Error: Unexpected solver message:
Program received signal SIGILL: Illegal instruction.
Backtrace for this error:
#0 dgtsv_mod_MOD_dgtsv
  •    at DGTSV.f:190*
#1 leqsol_MOD_leq_isweep
  •    at leqsol_mod.f:729*
#2 leqsol_MOD_leq_msolve
  •    at leqsol_mod.f:292*
#3 leq_bicgs_mod_MOD_leq_bicgs0
  •    at leq_bicgs.f:392*
#4 leq_bicgs_mod_MOD_leq_bicgs
  •    at leq_bicgs.f:91*
#5 solve_lin_eq_mod_MOD_solve_lin_eq
  •    at solve_lin_eq.f:165*
#6 v_m_star
  •    at solve_vel_star.f:513*
#7 solve_vel_star_mod_MOD_solve_vel_star
  •    at solve_vel_star.f:135*
#8 iterate_MOD_do_iteration
  •    at iterate.f:255*
#9 run_fluid
  •    at mfix.f:191*
#10 run_mfix
  •    at mfix.f:145*
#11 main_MOD_run_mfix0
  •    at main.f:85*
Error 2
#0 start_thread
  •    at ./nptl/pthread_create.c:442*
Any suggestion or advice?
Thanks
Fabio
conduit.mfx (14.0 KB)
Just another update.
I tried with a completely different simulation and I faced the same scenario.
Instead, when I run one of the example cases there are no issues. I then thought it was some compatibility issue, so for the first case I recreated the test from scratch on the Ubuntu machine directly but still no success…
Fabio
Are you running the default (prebuilt) solver? What happens if you build a custom solver? Please attach the output of cat /proc/cpuinfo on the Ubuntu machine. Thanks.
