Hi, Developers
It is found that the functions of these options on the SETTING pane are not explained in the user guides. Can you give us a brief explanation of them?
Best regards
wuming
Hi, Developers
Best regards
wuming
These are application settings which affect the entire MFIX application, not just the model you are editing. They mostly just affect the look and feel of the application. We will make sure the user documentation gets updated to include more information about these settings.
Hi, im using OpenSUSE Leap 15 with a dark application color scheme and it looks like this:
Is there a way to maintain my color scheme (for the rest of my apps and desktop) but changing the theme only for MFiX.
HI Lawrence. Have you tried changing âApplication Styleâ in the Settings pane? This will let you choose between a few different predefined styles. You have to exit and restart the application to see the changes.
If none of these settings give you what you want, you can try using âqt5ctâ, the Qt5 Configuration Tool. I use this on my Linux desktop. It defines an additional style âqt5ctâ where you can make more fine adjustments (fonts, colors etc). You might want to try that.
Also note that some colors in MFiX are hardcoded (for example the light grey background,) so even if you change color schemes not everything will change.
Hope this helps,
