Hello, developers. Where can I find the underlying code for the DEM and CGP models? Also, if I don’t want to use MFiX in the GUI interface, how can I run MFiX in code form on a Linux system?
Best wishes!
Building and running the MFiX solver outside MFiX GUI (“Batch mode”) is covered in the documentation here
DEM and CGP code is spread across many source files in MFiX, mostly in the des
subdirectory, e.g. des/calc_force_dem.f
Code that deals with CGP is labeled as CGDEM
internally, for example
$ grep -ir cgdem
des/write_des_data.f: IF(CGDEM) THEN
Thank you for your patient reply.
