Hey guys,
I’m trying to simulate a TFM that has really fast reaction, which absorbs most of the CO2 in the air as soon as air flows into the fluidized bed. usr_rates.f (2.4 KB) td_jelly_roll.mfx (25.9 KB)
When I increased the reaction rate coefficient to 100 (line 69 of usr_rates.f ), it gave me an error:
ERROR time_step.f:193
However, it did not happen when I had lower reaction rate coefficient (at 1 or 10). Does anyone know what is causing the error?
My guess is that my reaction rate function doesn’t involve the solid concentration, so when the solid reactant is used up in the cell, MFiX finds the solid concentration to be negative, which caused problem. Can someone confirm if that was correct?
If that’s the case, how can I fix it? I tried modifying line 70 of usr_rates.f to be
IF(X_s(IJK,ML) > c_Limiter) then
RATES(Reaction_1) = 100*c_CO2
ELSE
RATES(Reaction_1) = 0
ENDIF
But the build failed with the following error.
C:\Users\Administrator\td_jelly_roll\usr_rates.f:70:7:
1
Error: Rank mismatch in array reference at (1) (2/3)
CMakeFiles\udfs.dir\build.make:86: recipe for target ‘CMakeFiles/udfs.dir/C_/Users/Administrator/td_jelly_roll/usr_rates.f.obj’ failed
mingw32-make.exe[2]: *** [CMakeFiles/udfs.dir/C_/Users/Administrator/td_jelly_roll/usr_rates.f.obj] Error 1
CMakeFiles\Makefile2:117: recipe for target ‘CMakeFiles/udfs.dir/all’ failed
Makefile:148: recipe for target ‘all’ failed
BUILD FAILED
mingw32-make.exe[1]: *** [CMakeFiles/
Any input is appreciated! Thanks a lot!
Jack
