I’m interested in what procedure/tools you use to ensure hard-coded changes to the source files do not impact the existing functionality of the solver.
I looked at the Regression Testing section in the documentation but I think that it is outdated (or the path to the regression test setup file is incorrect).
I decided to search in the other directories for the setup file and found it in two locations:
- In tools/Python/: I tried to run regtest.py using the instructions in the README file but ran into some errors (I think the setup file assumes you already have benchmark data which actually isn’t there)
- In tests/: The setup file here seems to be running the same tests as the CCSE Tests → so I assumed this is the right version.
For running the test, I used AMReX’s Regression Testing tool and it worked. I’d like to confirm whether this is the recommended or standard approach, to ensure consistency with best practices. Let me know your thoughts.
NOTE: there was a small change I had to make to AMReX’s Regression Testing tool because of an error I was running into → not sure if this is relevant for this post
Kind Regards,
Tarun
