Hi everyone
When I installed OpenMPI on Centos7, it reported 7 errors as follows. How to solve these problem. Thank you.
[feiyang@k186 ~]$ sudo yum install openmpi-devel
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
Resolving Dependencies
→ Running transaction check
—> Package openmpi-devel.x86_64 0:1.10.7-5.el7 will be installed
→ Processing Dependency: openmpi = 1.10.7-5.el7 for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: libotfaux.so.0()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: liboshmem.so.8()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: libmpi_usempi.so.5()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: libmpi_mpifh.so.12()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: libmpi_cxx.so.1()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: libmpi.so.12()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
→ Processing Dependency: libhwloc.so.5()(64bit) for package: openmpi-devel-1.10.7-5.el7.x86_64
—> Package compat-openmpi16.x86_64 0:1.6.4-10.7.2.el7 will be installed
→ Processing Dependency: environment-modules for package: compat-openmpi16-1.6.4-10.7.2.el7.x86_64
→ Processing Dependency: libpsm_infinipath.so.1()(64bit) for package: compat-openmpi16-1.6.4-10.7.2.el7.x86_64
→ Processing Dependency: libosmcomp.so.4()(64bit) for package: compat-openmpi16-1.6.4-10.7.2.el7.x86_64
→ Processing Dependency: libesmtp.so.6()(64bit) for package: compat-openmpi16-1.6.4-10.7.2.el7.x86_64
—> Package hwloc-libs.x86_64 0:1.11.8-4.el7 will be installed
—> Package mvapich23.x86_64 0:2.3-4.el7 will be installed
—> Package openmpi.i686 0:1.10.7-5.el7 will be installed
→ Processing Dependency: librdmacm.so.1(RDMACM_1.0) for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: librdmacm.so.1 for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libquadmath.so.0 for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libosmcomp.so.4 for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libibverbs.so.1(IBVERBS_1.1) for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libibverbs.so.1(IBVERBS_1.0) for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libibverbs.so.1 for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libhwloc.so.5 for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libgfortran.so.3 for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libfabric.so.1(FABRIC_1.2) for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libfabric.so.1(FABRIC_1.1) for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libfabric.so.1(FABRIC_1.0) for package: openmpi-1.10.7-5.el7.i686
→ Processing Dependency: libfabric.so.1 for package: openmpi-1.10.7-5.el7.i686
—> Package environment-modules.x86_64 0:3.2.10-10.el7 will be installed
—> Package hwloc-libs.i686 0:1.11.8-4.el7 will be installed
→ Processing Dependency: libnuma.so.1(libnuma_1.2) for package: hwloc-libs-1.11.8-4.el7.i686
→ Processing Dependency: libnuma.so.1(libnuma_1.1) for package: hwloc-libs-1.11.8-4.el7.i686
→ Processing Dependency: libnuma.so.1 for package: hwloc-libs-1.11.8-4.el7.i686
→ Processing Dependency: libltdl.so.7 for package: hwloc-libs-1.11.8-4.el7.i686
—> Package infinipath-psm.x86_64 0:3.3-26_g604758e_open.2.el7 will be installed
—> Package libesmtp.x86_64 0:1.0.6-7.el7 will be installed
—> Package libfabric.i686 0:1.7.2-1.el7 will be installed
→ Processing Dependency: libnl-route-3.so.200 for package: libfabric-1.7.2-1.el7.i686
→ Processing Dependency: libnl-3.so.200(libnl_3) for package: libfabric-1.7.2-1.el7.i686
→ Processing Dependency: libnl-3.so.200 for package: libfabric-1.7.2-1.el7.i686
→ Processing Dependency: libatomic.so.1 for package: libfabric-1.7.2-1.el7.i686
—> Package libgfortran.i686 0:4.8.5-44.el7 will be installed
—> Package libibverbs.i686 0:22.4-6.el7_9 will be installed
→ Processing Dependency: rdma-core(x86-32) = 22.4-6.el7_9 for package: libibverbs-22.4-6.el7_9.i686
—> Package libquadmath.i686 0:4.8.5-44.el7 will be installed
—> Package librdmacm.i686 0:22.4-6.el7_9 will be installed
—> Package opensm-libs.i686 0:3.3.21-4.el7_9 will be installed
→ Processing Dependency: libibumad.so.3(IBUMAD_1.0) for package: opensm-libs-3.3.21-4.el7_9.i686
→ Processing Dependency: libibumad.so.3 for package: opensm-libs-3.3.21-4.el7_9.i686
—> Package libatomic.i686 0:4.8.5-44.el7 will be installed
—> Package libibumad.i686 0:22.4-6.el7_9 will be installed
—> Package libnl3.i686 0:3.2.28-4.el7 will be installed
—> Package libtool-ltdl.i686 0:2.4.2-22.el7_3 will be installed
—> Package numactl-libs.x86_64 0:2.0.9-6.el7_2 will be updated
—> Package numactl-libs.i686 0:2.0.12-5.el7 will be installed
—> Package numactl-libs.x86_64 0:2.0.12-5.el7 will be an update
—> Package rdma-core.i686 0:22.4-6.el7_9 will be installed
Removing rdma-core.i686 0:22.4-6.el7_9 - u due to obsoletes from installed mlnx-ofa_kernel-5.3-OFED.5.3.1.0.0.1.rhel7u4.x86_64
→ Restarting Dependency Resolution with new changes.
→ Processing Dependency: rdma-core(x86-32) = 22.4-6.el7_9 for package: libibumad-22.4-6.el7_9.i686
→ Processing Dependency: rdma-core(x86-32) = 22.4-6.el7_9 for package: librdmacm-22.4-6.el7_9.i686
→ Finished Dependency Resolution
Error: Package: libibumad-22.4-6.el7_9.i686 (updates)
Requires: rdma-core(x86-32) = 22.4-6.el7_9
Available: rdma-core-22.4-5.el7.i686 (base)
rdma-core(x86-32) = 22.4-5.el7
Installed: rdma-core-52mlnx1-1.53100.x86_64 (installed)
~rdma-core(x86-64) = 52mlnx1-1.53100
Available: rdma-core-22.4-6.el7_9.x86_64 (updates)
~rdma-core(x86-64) = 22.4-6.el7_9
Error: Package: compat-openmpi16-1.6.4-10.7.2.el7.x86_64 (base)
Requires: libosmcomp.so.4()(64bit)
Available: opensm-libs-3.3.21-3.el7_8.x86_64 (base)
Available: opensm-libs-3.3.21-4.el7_9.x86_64 (updates)
Installed: opensm-libs-5.8.2.MLNX20210321.2958ab8-0.1.53100.x86_64 (installed)
~libosmcomp.so.3()(64bit)
Error: Package: openmpi-devel-1.10.7-5.el7.x86_64 (base)
Requires: libmpi_usempi.so.5()(64bit)
Available: openmpi-1.10.7-5.el7.x86_64 (base)
Installed: openmpi-4.1.0rc5-1.53100.x86_64 (installed)
~libmpi_usempi.so.40()(64bit)
Requires: liboshmem.so.8()(64bit)
~liboshmem.so.40()(64bit)
Error: Package: librdmacm-22.4-6.el7_9.i686 (updates)
Requires: libmpi_mpifh.so.12()(64bit)
~libmpi_mpifh.so.40()(64bit)
Error: Package: libibverbs-22.4-6.el7_9.i686 (updates)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
