I am attempting to apply a fluid pressurization rate at a specific point using the usr1.f subroutine. Could you please review the implementation and confirm whether the approach is correct?
Below is the content of the usr1.f subroutine:
SUBROUTINE USR1
USE USR
USE fldvar, only: P_g
USE run, only: time
USE geometry, only: IMAX, JMAX, KMAX, X_MIN, Y_MIN, Z_MIN, DX, DY, DZ
IMPLICIT NONE
DOUBLE PRECISION :: FluidPressurizationRate
INTEGER :: I, J, K, IJK
DOUBLE PRECISION, PARAMETER :: x_target = -0.01, y_target = 0.01, z_target = 0.005
INTEGER :: i_target, j_target, k_target
! Initialize the pressurization rate
FluidPressurizationRate = 1000.0 ! Adjust this value as needed
! Convert the target coordinates to cell indices
i_target = MAX(1, MIN(IMAX, INT((x_target - X_MIN) / DX(1)) + 1))
j_target = MAX(1, MIN(JMAX, INT((y_target - Y_MIN) / DY(1)) + 1))
k_target = MAX(1, MIN(KMAX, INT((z_target - Z_MIN) / DZ(1)) + 1))
! Convert (I, J, K) to 1D index IJK
IJK = (i_target - 1) + (j_target - 1) * IMAX + (k_target - 1) * IMAX * JMAX + 1
! Apply pressurization rate only to the specific cell
P_g(IJK) = P_g(IJK) + FluidPressurizationRate * time
RETURN
END SUBROUTINE USR1
