I am trying to simulate the rotary drum tutorial - imposing tangential velocity. I am new to this. I believe I am supposed to create a text file with keyframe data(velocity and time) in the same directory as the mfix file.
also, few files are supposed to be used. i searched for those files(usr_mod.f ,…) in mfix source and copied to the same directory. I cant find one of the files,(usrnlst.inc) in the mfix source. Is my approach correct? please confirm
For a new project, we usually copy the files required to be modified into the project folder. Then compile mfix in project directory but with cmake pointing the original unmodified “source” directory.
From what I see, your usr_init_namelist.f seems to be unmodified meaning that you copied the unmodified source file to the project directory. Is this the case? Therefore, this may not do what you actually wanted. Have you looked into the actual tutorial files in this location?
Thank You. Yes, I did not modify the usr_init_namelist.f file. I am very new to this kind of simulation. It would be very much useful if you could elaborate cmake compiling process. I dont see this in the tutorial file in the mfix website.
From version 20 onwards, MFiX GUI has a built-in code editor which lets you modify Fortran files and handles copying files from the source to the project directory.
You don’t have to use CMake from the command line if you don’t want to - there’s a button in the GUI to compile MFiX.
In general, the mfix solver creation process is done in two steps:
Using cmake to let the code know the location of source files, modified files, type of optimization needed, etc. as well as the type of compilers to be used. This process is called configuration and this will in turn will generate a Makefile.
Using Makefile to compile and create the mfix executable.
In addition to @cgw 's answer, you can also compile in terminal in case if you use Linux. From the tutorial folder, you can, for example, use the following command:
Note that compiler options can also be specified when you build the solver by clicking the button, and this is the recommended way of doing it. We have tried to make the build process as simple as possible!
Thanks a lot. This is really helpful. I still cannot turn on the read_kf to true. I am trying to simulate the imposing tangential velocity tutorial. So, I initially created a drum geometry, regions for initial particles, inlet, outlet, and wall. Defined mesh, initial conditions, and boundary conditions. For this tutorial, I am asked to create a text file with time and velocity values. I have used the same values as in the default tutorial. Now when I copy the required .f and .inc files, I couldn’t find the usrnlst.inc in the mfix source. However, I proceeded with compiling with the build solver button. The building was successful. I believe for the keyframe file(the text document with velocity data) to be read, it is necessary to turn on the read_kf to true in the advanced pane. This is where I face issue. I couldnt find the read_kf option. I also tried copying the usrnlst.inc from the default tutorial, but then when I try compiling using the build solver button, it throws an error. I don’t know where I am going wrong. Please shed some light.
Go to Advanced pane. Click “+” to add keyword. Select ‘read_kf’ from the list of available keywords (you can type the name in to the search bar). Then click “Update key” on the add keyword popup.
Keywords appear in the Advanced popup if (a) they are already set in the project file or (b) the user adds them via the above procedure. We should probably simplify this so that keywords from usr_init_namelist.f are automatically added without this extra step. Note that read_kf is not set in the mfx file, just the usr_init_namelist.f, so it’s not getting picked up by the GUI. Will try to simplify this in the upcoming release.
