Hello,everyone!
Do you know how to output the solid phase angular velocity of DEM particles to the grid in MFIX?
Which.f files are needed?
Thank you.
If statistics are enough (min/max/mean/std. dev) you can use Monitors to save particle rotational velocity data - this will create a CSV file.
If you want the data for every particle, this can be done as a VTK output. It looks like in this case you get a scalar rather than vector
Thank you for your help!@cgw
I want the angular velocity data in the grid. Do you know how to operate it?
I’m not sure I understand your question.
Rotational data is per-particle not per-cell. So when you define the output, it has to be “Particle data”, not “Cell data”. Then you can select “Rotational velocity”.
Thank you for your help! @cgw
