Have any of you encountered this strange issue while debugging the case?
File "lib/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "lib/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "lib/site-packages/mfix_solver/pymfix.py", line 373, in <module>
main()
File "lib/site-packages/mfix_solver/pymfix.py", line 245, in main
if mype.value == 0:
NameError: name 'mype' is not defined. Did you mean: 'type'?
Could you provide some suggestions on how to resolve this issue? Thank you all!
