Hello everyone, I am Vikas Patel trying to design a cyclone separator that tends to separate the fine carbon particle from supercritical water which has 600 k temperature and 22 MPa. So please suggest the way because when I did the things then no separation is possible types of massage popup.
Hi Vikas. Please share the files you have created and the specific errors you are seeing. In the main menu you will find “Submit bug report”, this will create a .zip file containing all inputs.
Thanks,
