Hi, using the install token command from the website I keep getting the below server error message…? I’ve tried installing older versions like 19.2.2 where I saw the same issue in an old thread that was resolved, but still no luck. I tried erasing browser cache, logging out and back in, refreshing token, turning internet connection off and on…
conda create -n mfix-19.3.0 mfix=19.3.0 mfix-doc=19.3.0 mfix-gui=19.3.0 mfix-solver=19.3.0 mfix-src=19.3.0 -c https://mfix.netl.doe.gov/s3/83543452/15030788b6816420cb6015864e180f9c/conda/dist
Solving environment: failed
CondaHTTPError: HTTP 500 INTERNAL SERVER ERROR for url https://mfix.netl.doe.gov/s3/83543452/15030788b6816420cb6015864e180f9c/conda/dist
Elapsed: 00:01.610907
A remote server error occurred when trying to retrieve this URL.
A 500-type error (e.g. 500, 501, 502, 503, etc.) indicates the server failed to
fulfill a valid request. The problem may be spurious, and will resolve itself if you
try your request again. If the problem persists, consider notifying the maintainer
of the remote server.
