You should expect a very noisy signal. This is what I got with a mean rate of 0.00017 and an amplitude of 0.00007
Apply some smoothing (averaging) to that curve and you’ll see the sine wave.
How would I apply smoothing?
The plot window in MFiX uses a library “pyqtgraph” which is documented here
If you right-click on the plot then you get a menu, select “Plot Options”, I think Downsample (with Mean option) could be what you are after.
Otherwise, since the monitors are written as CSV files, you can plot it using some other plotting software such as Gnuplot or whatever other package are familiar with.
