Can i use MFIX to run a simulation for slurry transportation with a riser pipe with considerin non-
Newtonian fluid??
thanks
No. Not out of the box. But, as Sofiane always says, it’s an open source code, you can do anything you want with it.
If you need to simulate liquid-solid flow and consider the mixture as non-Newtonian fluid, you only need to implement a shear-thinning viscosity model (like Carreau-Yasuda model) with a UDF.
Thank you All, i really appreciate your feedbacks
