Good morning all. I am using a single Windows 11 workstation (64gb Ram, 32 core CPU) to run simulations using the MFix GUI on 24.2.1.
I have used the GUI solver builder to create a 32 thread SMP, which builds with no issues. When I come to run the simulation, it does not run and returns a message of “MFiX process has stopped
Previous MFiX run is resumable.” I have scrolled up in the log and there are no other errors preventing it. This issue is persistent across every simulation I try and run using SMP (even the tutorial examples). It will run fine, but slow, on the single mfixsolver.
Is there something I am doing wrong? I’m not sure what files I can upload to aid with this problem?
mixer_2024-07-25T141723.842296.zip (45.1 MB)
Here is the bug report. Doing some searching around, this seems to be an issue without a solution in Windows. Would setting up a dual boot Linux with MFix potentially solve this? Would I see significant reductions in simulation time?
