I try to build Custom Interactive Solver by using command line,but there are something errors about building mfixsolver.I don’t know what these error mean.I don’t modified the codes about these errors.
The command line are these: source activate mfix-21.4 source /public3/soft/modules/module.sh module purge module load mpi/intel/17.0.5-cjj-public3 env FC=mpiifort build_mfixsolver --batch --dmp
I have updated about the source code I use.
Thank you very much. model.zip (29.1 MB)
Please attach the log files from the build, not just a screenshot. I can’t see enough of the build output in the picture.
In the model.zip you uploaded there is a file build/CMakeFiles/CMakeError.log which contains the lines
use mpi_f08
1
Fatal Error: File 'mpi_f08.mod' opened at (1) is not a GNU Fortran module file
gmake[1]: *** [CMakeFiles/cmTC_80c37.dir/test_mpi.f90.o] Error 1
gmake[1]: Leaving directory `/public3/home/sc55675/anaconda3/envs/mfix-21.4/share/mfix/src/model/build/CMakeFiles/CMakeTmp'
gmake: *** [cmTC_80c37/fast] Error 2
but this doesn’t match the the multiple definitions errors in your screenshot so I’m not sure what’s going on.
It’s strange that the Intel Fortran compiler is complaining about ODEPACK which is an old library for solving differential equations. I haven’t tried building MFiX with Intel Fotran in a long time but it should work. Is there another compiler version you can try? Also try removing the build directory completly between attempts, especially if you are changing compiler versions.
