I want to obtain the spatial profile of a quantity (say gas volume fraction) in a fluidized bed. In other words, I want to obtain a quantity (like gas volume fraction) versus time at a specific point in the fluidized bed. How can I do it? Is there any specific output file, where I can extract this information? If yes, where is it?
You can use the monitors to log volume fraction. Go to the monitor pane, click the +
button, select the output type to be “cell data,” a monitor type (reduction operator), and a region (defined on the regions pane) to define the point/plane/volume to apply the monitor to. Finally, select which variable you want to log (Volume fraction).
Thanks for the reply. However, I want to monitor the value (not average, max, min, standard deviation , …) at a specific point vs time. The problem is that “value” is inactive in “Monitor type” menu, as you see in the picture below. I can get the average, max, min, … of a quantity (like void fraction) in a region. However, it seems that I am not able to monitor the value of a quantity in a specific node (or mesh) in a region vs time.
To get the value of a single cell, you need a region that is a point (not a plane or volume). So on the regions pane, make all the from
and to
the same value for the X
, Y
, and Z
. The the region shape
will be point
And you can select Value
in the monitors popup.
Many thanks for your help
