I have been trying to port some simulation setups from mfix-21.1.4 to newer versions, the latest attempt being for mfix-22.1. Each time I run my cases using newer mfix versions (starting with mfix-21.2) I get a floating-point exception. In most cases, I have successfully run these cases with mfix-21.1.4 without the floating-point exception. Using gdb, I have traced this error to my usr_properties.f module. There, I define an array to collect the mass fraction of all the species and subsequently use the sum as a denominator in an equation. For some reason, the sum of the mass fraction of all the species returns zero and generates the floating-point exception.
Backtrace for this error:
Program received signal SIGFPE: floating-point exception - erroneous arithmetic operation.
#0 0x2B013949CC67
#1 0x2B013949BE60
#2 0x2B0139F303FF
#0 0x2B5DCB865C67
#1 0x2B5DCB864E60
#2 0x2B5DCC2F93FF
#0 0x2AEFB77D4C67
#1 0x2AEFB77D3E60
#2 0x2AEFB82683FF
#0 0x2BA61297AC67
#1 0x2BA612979E60
#2 0x2BA61340E3FF
#3 0x407C65 in usr_prop_mug_ at usr_properties.f:72
#4 0x492AC4 in __usr_prop_MOD_calc_usr_prop at usr_prop_mod.f:158
#5 0x6698E2 in __calc_mu_g_mod_MOD_calc_mu_g at calc_mu_g.f:39
#6 0x5D60E4 in __transport_prop_mod_MOD_transport_prop at transport_prop.f:64 (discriminator 1)
#7 0x499EEF in __calc_coeff_mod_MOD_calc_coeff at calc_coeff.f:344
#8 0x524C20 in __iterate_MOD_do_iteration at iterate.f:241
#9 0x4854B6 in run_fluid at mfix.f:188
#10 0x485BCD in MAIN__ at mfix.f:298
