Stability issues when introducing CSG Geometry in MFIX-Exa
Hi everyone,
I am relatively new to MFIX-Exa and have been progressing through increasingly complex cases. Recently, I’ve hit a bottleneck with simulation stability.
My CFD-DEM simulations run perfectly fine (stable and converging) when using a simple box/domain without complex geometry. However, as soon as I introduce CSG geometry, the simulation becomes unstable or diverges early on.
I suspect the “small cell” problem where fluid cells are cut by the CSG boundary.
Questions:
What are the best practices for mesh refinement around CSG boundaries to prevent Divergence?
Should I be looking at the mfix.fixed_dt or letting the adaptive time-stepping handle the reduction?
Any advice on the common gotchas when moving from box-simulations to CSG-defined boundaries would be greatly appreciated!
Case:
geometry.csg (456 Bytes)
inputs.txt (8.1 KB)
Outputs:
mfix.out.txt (336.5 KB)
Backtrace.3.txt (3.3 KB)
Backtrace.2.txt (3.3 KB)
Backtrace.1.txt (3.9 KB)
Backtrace.0.txt (3.3 KB)
Update: Stability issues resolved by addressing small cut cells.
Settings borrowed from @YupengXu
mfix.grid_pruning = true
amr.refine_grid_layout = false
eb2.cover_multiple_cuts = true
eb2.maxiter = 1024
eb2.small_volfrac = 0.1
