Hi, im using the Software for an uni Project. Unfortunately I got Problems reading the stl files of the tutorial Case PIC 3D cyclone with my Mac OS. when I open the new file with the case I get this error.
qt.qpa.fonts: Populating font family aliases took 171 ms. Replace uses of missing font family “.AppleSystemUIFont” with one that exists to avoid this cost.
2024-02-08 13:23:16.278 ( 61,919s) [mfix: cyclone_pi] vtkSTLReader.cxx:658 ERR| vtkSTLReader (0x600001c8a080): STLReader: error while reading file geometry.stl at line 4: Parse error reading STL vertex
2024-02-08 13:23:16.279 ( 61,921s) [mfix: cyclone_pi] vtkExecutive.cxx:741 ERR| vtkCompositeDataPipeline (0x600001b1f000): Algorithm vtkSTLReader (0x600001c8a080) returned failure for request: vtkInformation (0x600008de42a0)
Debug: Off
Modified Time: 15084294
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FROM_OUTPUT_PORT: 0
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
when I start the simulation I get a Warning but the Stl data can be read but I think it is only one dimension read
this is the Warning that I get Warning: UNABLE TO PROPAGATE F_AT ARRAY FROM myPE=. 0
THIS USUALLY INDICATE A RANK WITH NO ACTIVE CELL
YOU MAY NEED TO ADJUST THE GRID PARTITIONING
TO GET BETTER LOAD_BALANCE.
INTERSECTING GEOMETRY WITH U-MOMENTUM CELLS…
INTERSECTING GEOMETRY WITH V-MOMENTUM CELLS…
and the Simulation needs Ages to and can’t even calculate 1 time Step
what can I do ? thanks
Vico
