Thank you for the patches of 13 October in the des_unpack_parcross thread. I had found the two LSD problems that 0005 fixes, and tests of 26.1.2 with 0001-0009 agree with it:
- Two rounded cubes after an elastic, frictionless collision spin at 178.2 and 144.1 rad/s (4991 and 4898 rad/s without the patches; LIGGGHTS-PUBLIC 3.8 gives 175.8 and 144.8).
- A pair of cubes of 2500 and 1000 kg/m³ rebounds with a restitution of 0.898 for an input of 0.9 (0.148 without the SQRT(M_EFF) factor; LIGGGHTS 0.898).
I also found five problems in the superquadric drag that the patches do not touch. The attached series 0010-0015 fixes them. It applies after 0001-0009 on 26.1.2 without offset or fuzz (patch -p1 in the directory that holds model/).
- 0010: a flow along the particle’s z axis gave every shape a crosswise sphericity of 1 and the area of the volume-equivalent sphere. A cylinder with its axis along the flow got the drag of another shape, and a tilt of 1 degree changed its slip by 89 percent.
- 0011: the projected area of a cuboid had a lower bound, the mean of its three face areas: 4.5 instead of 3 mm² for a 3 x 2 x 1.5 mm box seen along its 3 mm edge.
- 0012: the Holzer-Sommerfeld force multiplied C_d by the projected area, although C_d already contains the orientation through the crosswise sphericity, and Holzer and Sommerfeld refer it to the volume-equivalent sphere.
- 0013: Re used the bounding diameter instead of the volume-equivalent diameter, 1.38 to 1.59 times larger for the shapes we tested.
- 0014 (DES caller) and 0015 (TFM caller): the orientation came from the fluid velocity instead of the slip, so in a fluid at rest every shape and orientation had a crosswise sphericity of 1.
Each patch message gives the reason and the test numbers. How we tested:
21 one-particle decks (cuboid, cylinder, spheroid and sphere; both SQP drag types; upflow and fluid at rest), run with the serial solver on seven builds, from 26.1.2 with 0001-0009 to the full series (147 runs). The terminal slip equals an independent evaluation of the coded formulas to 4.2e-5 (relative). The only exceptions are the fluid-at-rest runs before 0014, at up to 4.7e-4, where the orientation comes from the small fluid velocity the particle induces.
The sphere is unchanged, except for a rounding difference of at most 3e-8 m/s after 0013.
The same decks with DMP (3 ranks along the fall) and SMP (4 threads) builds, before and after the series (84 runs): SMP is identical to serial in every output frame. With the full series, DMP agrees with serial to 1.7e-5 in the terminal slip, and in 10 of the 21 runs the particle crosses a rank boundary. The fb_sqp_particle_input tutorial, run to 0.1 s with the full series in DMP and serially, keeps all 72 particles and gives the same mean particle height and speed.
All builds (serial after each patch, DMP and SMP) compile with gfortran 13.1 without warnings.
0015 changes no DES result. It compiles, but
SuperDEM_drag_patches_0010-0015.zip (44.2 KB)
we did not run a TFM case with an SQP drag type.
DRAG_SQP_GIDASPOW_ganser also takes Re from the bounding diameter and, in its dilute branch, refers the force to the projected area, but no drag type selects it in 26.1.2, so I left it unchanged.
The zip holds the six patches, the 21 decks, the results of the serial and parallel runs, the evaluation script (sqp_drag_check.py, numpy only) and a README.
