Hello, I filled in the value of k-e during the setting, but I kept reporting an error value that was not filled in during the running, and the following error occurred. May I ask why? Thank you!
mfix_2022-11-07T154010.997970.zip (37.0 KB)
I think we’re looking at two separate problems here. The file .visual_props is supposed to contain the state of the model view in MFIX- it normally looks something like
{"mesh": {"color": "#f44328", "visible": true, "opacity": 1.0, "rep": "solid", "color_by": "Volume", "edge": "#7a2114"}, "background_mesh": {"color": "#64b6f7", "visible": true, "opacity": 1.0, "rep": "wire", "edge": "#325b7b"},
while your file contains some garbage:
@GCC: (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0��08` �
��� ,$p$�=�=�=�?@@��
I don’t understand how this happened but if you delete .visual_props from the project directory you should get past the loading error. You will have to set up the view again.
Separately from this I cannot load the file mazhangke_shiyan.mfx because it is not a valid MFIX file - just a lot of Х@é��kK�r���zUM�˝���
Did the file get corrupted somehow?
mazhangke_shiyan_2022-11-08T162045.745954.zip (61.3 KB)
Thank you for your reply. I have uploaded the file again. Could you please help me check the problem? Thank you very much!
You have found a bug in the MFiX GUI, the values entered for the turbulence parameters are not getting saved to the project file correctly for “compound” regions like the mass inflow “in1+in3+in5”
We will release a fix for this soon, but in the meanwhile you can work around the problem in 2 ways:
.mfx file in an external editor and add the lines: bc_e_turb_g(1) = 0.00189
bc_k_turb_g(1) = 0.00375
bc_e_turb_g(2) = 0.00189
bc_k_turb_g(2) = 0.00375
these can be anywhere in the top section of the file where keywords are set (before the # Chemical reaction section, etc)
Then reload the file in MFiX and run the simulation
Thanks for the bug report, this will get fixed ASAP
Another workaround:
$ cd $CONDA_PREFIX
$ vi ./lib/python3.10/site-packages/mfixgui/project.py
change line 466 of the file from
self.args = args
to
self.args = args.copy()
Thank you very much for your reply, the problem is solved, thank you!
