The error occurred after importing the trapezoidal geometry
Dear Developer,
I encountered the following error in MFIX after importing a trapezoidal geometry and running a simple case. I am unsure how to proceed with adjustments. I would greatly appreciate it if you could provide the cause of the error or offer suggestions to help resolve it. Thank you very much.
Best regards
11_2024-10-12T000835.227031.zip (65.4 KB)
The message suggests to check the mesh settings, and I find that you have set the number of cells to 1… this will not work. You need a finer mesh.
shot-2024-10-11_13-53-22
Dear Developer,
Thank you for your response and clarification. I tried refining the mesh, and indeed, the previous error no longer occurs. However, when I start the simulation, the time step continuously decreases until an error occurs. I have tried several different refined mesh combinations (such as 15,60,2; 20,28,2; 20,100; 2,20,120,3, etc.), but the same error, “dt < dtmin,” appears, possibly indicating that the calculation is not converging. How can I reasonably set up my mesh to ensure the case runs smoothly?
Best regards!
