Hi, I am running a CFD-DEM heat transfer case on MFIX 21-3. But it always breaks without showing any error.
When I delete the custom solver (I want to output the heat transfer amount so i changed some file.),it can run well. test.zip (7.9 MB)
Then i changed to MFIX-22.3, this time it said as follows
Backtrace for this error:
#0 calc_thermo_des_mod_MOD_calc_thermo_des
at [test/calc_thermo_des.f:66](test/calc_thermo_des.f:66)
#1 des_time_march_MOD_des_time_step
at [des/des_time_march.f:195](des/des_time_march.f:195)
#2 run_dem
at [mfix.f:210](mfix.f:210)
#3 run_mfix
at [mfix.f:145](mfix.f:145)
#4 main_MOD_run_mfix0
at [main.f:79](main.f:79)
Looking at where RXNS_Qs is allocated (model/des/des_allocate_mod.f)
! BEGIN Species Allocation
IF(ANY_SPECIES_EQ)THEN
Allocate( RXNS_Qs( MAX_PIP ) )
ENDIF
! End Species Allocation
You do not have species equations enabled for any of the phases, so the variable RXNS_Qs is unallocated.
Note that it is generally easier to debug on the Linux platform since not all of the debugging tools and libraries we depend on are available for Windows. We are working on improving the support for debugging solver problems on Windows.
