The parameters set will change after saving
Hello researchers, Recently, I discovered a bug-like issue when using CGP for simulation calculations. The specific description is as follows: Initially, I set the weight coefficient to 4.0, as shown in the following figure. When I reset the task and set the weight coefficient to 2.0 or other numerical values, after clicking save, the weight coefficient automatically changes to 4.0. I have tried several times, and this phenomenon has persisted. As long as you click save, the weight coefficient will change to its original value. I’m not sure if this is a bug in the mfix software under Windows, but I have attached an error report.
2dd_2023-11-29T164553.601943.zip (308.0 KB)
This is indeed a bug in MFiX, thank you for the report. This will be fixed in the upcoming 23.4 release (late December)
For now, you can fix this by:
  1. Exit MFiX
  2. Back up the file CGP.mfx
  3. Open the file CGP.mfx in a text editor
  4. Delete these 6 lines starting with !MFIX-GUI retained keys
#!MFIX-GUI retained_keys = {"mw_avg": 29.0, "ro_g0": 1.0, "c_pg0": 1005.0,
#!MFIX-GUI   "particles": 0, "ro_s0(2)": 1000.0, "c_ps0(2)": 830.0, "k_s0(1)":
#!MFIX-GUI   1.0, "k_s0(2)": 1.0, "ro_xs0(2,1)": 708.0, "x_s0(2,1)": 0.41,
#!MFIX-GUI   "ro_xs0(2,2)": 450.0, "x_s0(2,2)": 0.0, "ro_xs0(2,3)": 450.0,
#!MFIX-GUI   "x_s0(2,3)": 0.01, "inert_species(2)": 3, "cgp_stat_wt(2)": 1.0,
#!MFIX-GUI   "cgp_stat_wt(1)": 4.0, "cgp_d_p0(2)": 0.0006, "cgp_d_p0(1)": 0.01}
Upon restarting MFiX you should be able to change the weight parameter.
Sorry for the trouble, and thanks for the bug report.
Thank you very much for your reply. Thank you again.
