The simulation,The reaction is getting slower and slower
When I am not using pulse airflow, although its response slows down, it is within the normal range. However, after adding pulse airflow, the simulation time becomes longer and longer after 5 seconds of response, and it takes 82 days to complete,
You should describe your problem more detailedly. It’s suggested that uploading your sumulation files so that others can check your parameter settings and make reasonable advice.
