The system is initiated with no particles and no solids inlet was detected
I ran the program and I got this warning message :
Warning from des/set_bc_dem.f:51
Warning 1202: The system is initiated with no particles and no solids inlet was detected.
You find attached the file
I wanted also to add the keyword read_kf but I couldn’t.
Any help please!
I think your file attachement failed. Go to the main menu, select “Submit bug report” and upload the resulting ZIP file.
Note that the read_kf keyword is not part of the base MFiX, it is an extra keyword added to a few of the tutorials (conveyor3d, rotating drum, mixer3d). It is implemented via UDFs: usrnlst.inc and usr_init_namelist.f which allow you to add additional keywords. Take a look at the conveyor3d tutorial for more info.
Thank you for your reply.
I couldn’t upload the zip file. You can find it on this link
Zip File
For the keywork, I wanted to make the cylinder rotate so I added the keyword to fix the velocity of the cylinder …
