When creating geometries in OpenSCAD, make sure there is overlap between separate components.
Faces that are flush (touching but not overlapping) probably will not create the EB geometry successfully in MFIX-Exa because it the touching faces maybe interpreted as walls.
Be mindful of “round off” when specifying the overlap. For example,
y = 10. + 1e-8will probably get rounded to10.so you do not get the tiny overlap you wanted.
