Ascent allows you to set up multiple renders of the same scene, which can be useful for comparing different views.
This feature is only available if mfix is compiled with the Ascent and Conduit libraries. A few examples of building these tools on several high-performance systems are provided in the MFIX-Exa documentation.
We’ve observed that sometimes simulations appear to hang when multiple renders are used. To avoid this issue, we recommend configuring your YAML files to use only one render per scene.
Attached is a complete YAML file that you can run with benchmarks/01-HCS/Size0001 by including the following keywords in the inputs file.
mfix.ascent_int = 10
ascent.actions = ascent_actions.yaml
Key elements in the YAML file:
pipelines- Define the fluid and particle data to visualize:- We construct a fluid velocity vector field (
vel_g) from the componentsu_g,v_g, andw_g, and compute its magnitude (vel_g_mag). - For particles, we build a velocity vector (
V) fromvelx,vely, andvelz, and compute the magnitude (vel).
scenes– Specify what to visualize and how:plots– Select the data to displayp1: fluid velocity magnitudep2: particle velocity magnitude
renders– Define camera views:r1: isometric viewr2: isometric view, zoomed out
Avoid combining multiple renders (e.g., r1 and r2) under the same scene. Instead, define two separate scenes, each with a single render. This approach improves stability and prevents simulation hangs.
Example output from attached actions file
- Left: output of
r1- an isometric view of fluid slices and particles - Left: output of
r2- same view asr1but further away
