I recently bought an Alienware desktop with Windows OS. I installed MFix on it.
I am unable to give a run for a DEM simulation with SMP. It is working for TFM though.
It starts the simulation and abruptly ends with:
MFiX process has stopped
Previous MFiX run is resumable.
This job runs on Linux with 4 SMP threads, but on Windows I get the same failure you are seeing, without any helpful messages. The job runs on Windows if I use the non-SMP solver.
Unfortunately we do not have good debugging tooks on Windows and I’m not sure I’ll be able to fix this, since I don’t have good visibility into what’s going wrong.
Is it possible to set up a Linux machine for your work? You may find other advantages to doing so as well (jobs tend to run faster, debugging code is easier, etc).
Okay here is something:
Mfix 23.2 version required me to build SMP solver. I did that and it worked. 23.3.2 and 23.4.1 don’t work. You could look into why…but yeah. Hope it helps.
